What Settings Are Needed For MSM Layer 2 Fast Roaming?
MVP
MVP
Q:
What MSM controller settings are needed for client layer 2 fast roaming?
A:
Disable the Access control option under the Global section on the VSC page.
Install a Mobility or Premium license on the controller .
All APs must be on the same layer 2 network.
All APs must have VSCs with the same name, SSID, and wireless protection settings.
 The wireless protection must be WPA2, or WPA2 with 802.1X.
Version history
Revision #:
1 of 1
Last update:
3 weeks ago
Updated by:
