Where to enable uplink loadbalancing for BoC in 8.x?
MVP Expert
MVP Expert
Q:
A:
Aruba supports 3 types of uplink load balancing:
uplink-utilization
round robin and
session counts.
When uplink load balancing is enabled, the traffic will be distributed to multiple uplinks according to the configured load balancing method.
Below is the place where to enable the uplink loadbalancing
Version history
Revision #:
1 of 1
Last update:
‎07-31-2019 05:18 AM
Updated by:
