Why CPSEC whitelist entry to HA standby controller goes to unapproved state?
MVP
MVP
Problem:
Network setup:
Master <---> set of local controllers as HA Active/Standby
With CPSEC enabled, AP would not form its HA standby tunnel with HA standby controller. In errorlog, we would see XAUTH failed due to AP not found in whitelist DB.
Diagnostics:
With Auto-provisioning enabled, when AP talks to the controller first, a CPSEC entry is created on that controller with "approved-ready-for-cert" state. If the AP does not come up on that same controller within 2 hours then the CPSEC entry would move to unapproved state.
Check if AP's MAC address is present in whitelist entry of Master and HA controllers.
(HA-standby) #show whitelist-db cpsec
Control-Plane Security Whitelist-entry Details
MAC-Address  AP-Group  AP-Name  Enable  State  Cert-Type  Description  Revoke Text  Last Updated
Total Entries: 0
(HA-standby) #show ap database
AP Database
Name  Group  AP Type  IP Address     Status  Flags  Switch IP     Standby IP
AP2   test   365      10.29.165.245  Down    2      10.29.164.30  0.0.0.0
(HA-standby) #show log errorlog 10
Aug 20 12:20:50 <isakmpd 103067>  <3994> <ERRS> |ike|  IKE XAuth failed as the AP 44:48:c1:ca:66:ec is not in whitelist
Aug 20 12:20:53 <localdb 133006>  <4176> <ERRS> |localdb|  User 44:48:c1:ca:66:ec Failed Authentication
Aug 20 12:20:53 <authmgr 522275>  <4137> <ERRS> |authmgr|  User Authentication failed. username=44:48:c1:ca:66:ec userip=10.29.165.245 usermac=44:48:c1:ca:66:ec authmethod=TRANSPORT-VPN servername=Internal serverip=10.29.164.10 apname=N/A bssid=00:00:00:00:00:00
Solution
We can manually add the AP in whitelist entry on HA standby controller as below;
(HA-standby) #whitelist-db  cpsec add mac-address 44:48:c1:ca:66:ec ap-group test ap-name AP2
44:48:c1:ca:66:ec  test      AP2      Enabled  approved-ready-for-cert  switch-cert                            Tue Aug 21 10:29:24 2018
Total Entries: 1
AP Database
AP2   test   365      10.29.165.245  Up 2m:16s  2S     10.29.164.20  10.29.164.30
If we check CPSEC, it is enabled and Auto cert provisioning and allow all were enabled. So, our expectation is Whitelist DB should be synced between controllers.
(HA-standby) #show control-plane-security
Control Plane Security Profile
Parameter                    Value
Control Plane Security       Enabled
Auto Cert Provisioning       Enabled
Auto Cert Allow All          Enabled
Auto Cert Allowed Addresses  N/A
However, if we check in Master controller, we see Whitelist DB sync was disabled.
(Master) #show whitelist-db cpsec-status
My Mac-Address                00:1a:1e:03:d1:c8
My IP-Address                 10.29.164.10
Master IP-Address             10.29.164.10
Switch-Role                   Master
Whitelist-sync is disabled
So, with whitelist DB sync disabled and HA Active/Standby setup; whitelist entry on HA active controller is added automatically once the AP talks to that controller. But, if the controller is in standby role, the entry is not added in controller automatically. Hence, the AP fails to come up on HA standby controller when whitelist DB sync is disabled on Master controller and entry is not added manually on HA standby controller.
Version history
Revision #:
2 of 2
Last update:
‎02-26-2019 11:13 PM
Updated by:
Labels (1)
Contributors
