Aruba Central - Configuration using Templates
MVP
MVP
How to map a certificate to Instant AP using template configuration?
This article applies to all Instant APs which are provisioned and managed by Aruba Central.
Below are the steps to map/upload a certificate to an Instant cluster which is managed by Aruba Central and provisioned to a Template Group.
1. Navigate to Global Settings -> Certificates and upload the certificate you want to map to specific Template Group.
2. Once the certificate is uploaded, make a note of the cert name and the checksum value from the same location. Here the name is "webcert" and checksum value corresponds to that cert.
3. Move to the corresponding template group and you can configure any of the below option in the template
server-cert-checksum <cert-name/checksum value>
ca-cert-checksum <cert-name/checksum value>
cp-cert-checksum <cert-name/checksum value>
radsec-cert-checksum <cert-name/checksum value>
radsec-ca-checksum <cert-name/checksum value>
All the above commands can be used to map any type of certificate to Instant AP.
Once the certificate is uploaded to the template configuration, get into the AP console to verify if the certificate is being pushed to Instant cluster or not.
Aruba# show cert all
Current Server Certificate:
Version       :3
Serial Number :5D:BA:62:7D:74:47:67:83
Issuer        :/C=US/ST=Arizona/L=Scottsdale/O=GoDaddy.com, Inc./OU=http://certs.godaddy.com/repository//CN=Go Daddy Secure Certificate
 Authority - G2
Subject       :/OU=Domain Control Validated/CN=clearpass.la.gov
Issued On     :Aug 23 17:41:00 2017 GMT
Expires On    :Aug 23 17:41:00 2020 GMT
Signed Using  :SHA256-RSA
RSA Key size  :2048 bits
Version       :3
Serial Number :
Issuer        :/C=US/ST=Arizona/L=Scottsdale/O=GoDaddy.com, Inc./CN=Go Daddy Root Certificate Authority - G2
Subject       :/C=US/ST=Arizona/L=Scottsdale/O=GoDaddy.com, Inc./CN=Go Daddy Root Certificate Authority - G2
Issued On     :Sep  1 00:00:00 2009 GMT
Expires On    :Dec 31 23:59:59 2037 GMT
Version       :3
Serial Number :07
Subject       :/C=US/ST=Arizona/L=Scottsdale/O=GoDaddy.com, Inc./OU=http://certs.godaddy.com/repository//CN=Go Daddy Secure Certificate
 Authority - G2
Issued On     :May  3 07:00:00 2011 GMT
Expires On    :May  3 07:00:00 2031 GMT
Default CP Server Certificate:
Version       :3
Serial Number :01:DA:52
Issuer        :/C=US/O=GeoTrust Inc./OU=Domain Validated SSL/CN=GeoTrust DV SSL CA
Subject       :/serialNumber=lLUge2fRPkWcJe7boLSVdsKOFK8wv3MF/C=US/O=securelogin.arubanetworks.com/OU=GT28470348/OU=See www.geotrust.co
m/resources/cps (c)11/OU=Domain Control Validated - QuickSSL(R) Premium/CN=securelogin.arubanetworks.com
Issued On     :May 11 01:22:10 2011 GMT
Expires On    :Aug 11 04:40:59 2017 GMT
Signed Using  :SHA1-RSA
Version       :3
Serial Number :02:36:D2
Issuer        :/C=US/O=GeoTrust Inc./CN=GeoTrust Global CA
Subject       :/C=US/O=GeoTrust Inc./OU=Domain Validated SSL/CN=GeoTrust DV SSL CA
Issued On     :Feb 26 21:32:31 2010 GMT
Expires On    :Feb 25 21:32:31 2020 GMT
Version       :3
Serial Number :02:34:56
Subject       :/C=US/O=GeoTrust Inc./CN=GeoTrust Global CA
Issued On     :May 21 04:00:00 2002 GMT
Expires On    :May 21 04:00:00 2022 GMT
Device Certificate:
Version       :3
Serial Number :25:F1:A9:EB:00:00:00:5D:72:5B
Issuer        :/UID=com/UID=arubanetworks/UID=ca/CN=DEVICE-CA1
Subject       :/CN=AX0532939::9c:1c:12:c5:b8:2c
Issued On     :Nov 12 18:52:05 2013 GMT
Expires On    :Sep 14 03:21:14 2032 GMT
From this output you can see the "Current server certificate" has been changed after we uploaded it to the template configuration whereas the "default CP server certificate" and "device certificate" remains to be default.
Version history
Revision #:
2 of 2
Last update:
‎03-18-2019 10:09 PM
Updated by:
Contributors
