Dual uplink in Instant AP
MVP
MVP
Q:
How does dual uplink work in Instant AP?
A:
Dual Uplink feature in Instant AP is only intended for Standalone mode.
For instant AP to operate as dual uplink, eth1 port of the Instant AP should be configured as uplink.
1. To enable uplink for eth1 port, Navigate to More > Wired > Create New Wired Network > Click on Show advanced option and enable the uplink knob and map it to the eth1 (0/1) port
2. Configure the vlan as access or trunk as per the requirement.
When the primary link (eth0) goes down then eth1 port will become the uplink for the Instant AP.
Note: Instant APs will join the cluster with eth1 port as uplink.
Version history
Revision #:
2 of 2
Last update:
‎03-15-2019 01:23 PM
Updated by:
Labels (1)
Contributors
