This community is currently in a read-only state due to a maintenance window. For more info click here
Enabling ble-console in IAP from Aruba8.6.x.x
MVP
MVP
To be able to access Ble-console of an AP using BLUConsole app starting 8.6.X
From 8.6 BLE-opmode  for ble-console operation been deprecated. We have to configure IOT radio profile to enable ble-console as it is disabled by default.
Ble opmode been restricted to beacon, Scan and both.
(IoT Radio Profile "Test") # ble-opmode ?
<opmode>     beac scan or both
In order to get the ble-console enabled we need to create IOT radio profile to have this option enabled,
(config) # iot radio-profile Test
(IoT Radio Profile "Test") # ble-console ?
<console>     off on or dynamic
(IoT Radio Profile  Test") # ble-console on
(IoT Radio Profile  Test") # exit
(config)# exit
# commit apply
We need to map the profile in use using the below command,
(config) # iot use-radio-profile Test
(config)# exit
# commit apply
From  running-configuration, you would be seeing the below config,
ble-console on
# show ap debug ble-config
9c:8c:d8:cf:c6:86# show ap debug ble-config
---------- IOT Radio Profiles -----------------
Profile Name        : Test
Radio Instance      : Internal
Radio Mode          : BLE
BLE Mode            : beaconing scanning
BLE Console         : On
BLE Tx Power (dBm)  : 0
Note: No Zigbee service profiles configured.
Radio Configuration
Radio Information  NORDIC ONBOARD Internal BLE Zigbee
Miscellaneous Configuration
Item                            Value
FIPS Mode                       No
Master IP                       127.0.0.1
BLE Ready                       Yes
APB Info Update Intvl (in sec)  87 (430464/430414)
BLE debug log                   Enabled
Message Selector                0xffff (APB: 0xffff)
AP Deep Sleep Duration          120 minutes
AP USB Power Override           Disabled (-1)
Uplink Status                   Up
APB Connection Status           0
Time Last Message to APB        1970-01-01 00:00:00
Log Levels Available            { All(0x1fffff), Info(0x04), Warning(0x02), Error(0x01), Ageout(0x08), BMReq(0x10), FW-Upgrade(0x20), FW-UpgradeErr(0x40), CfgUpdate(0x80), CfgUpdateErr(0x100), Beacon(0x200), BcnTLV(0x400), BcnErr(0x800), APB(0x1000), Tags(0x2000), ZF(0x4000), AMON(0x8000), IOT-GW(0x10000), AT-HTTPS-JSON(0x20000), AT-WEBSOCKET-PROTOBUF(0x40000), Enocean(0x100000), (0x00), None(0x00) }
Current Log Level               { 0x901e1 : Error(0x0001), FW-Upgrade(0x0020), FW-UpgradeErr(0x0040), CfgUpdate(0x0080), CfgUpdateErr(0x0100), IOT-GW(0x10000) }
Log Mac Filter                  None
Note: No IoT transport context configured. Config ID:0
Note: Uplink status is applicable only for Controller with Dynamic Console operational mode.
      For APBs of type LS-BT1USB, applied operational mode is Beaconing if ap system profile setting is either Persistent or Dynamic.
Note: Setting Message Selector value to 0x0 will cause the APB to function improperly. Use the knob with caution.
Note: Message Selector Bits: All(0xffff), V0 Scan (0x01), V1 Scan (0x02), UI Scan (0x04), Proximity Advert (0x08), IBeacon (0x10), Heartbe
at-1 (0x20),  Heartbeat-UI (0x40), Upg Ack (0x80), Heartbeat-2 (0x200), Generic Scan (0x400), Generic Advert (0x800), Tag V1 Scan (0x1000), Tag V1 Advert (0x2000)
9c:8c:d8:cf:c6:86# show ap deb ble-database
BLE APB Information
AP Name            AP Group  BLE MAC            BLE Cur. Bank   BLE Opp. Bank  AP Eth MAC         AP IP           Reported at           ConfigID  Status
9c:8c:d8:cf:c6:86            20:4c:03:45:c6:e8  DFU APP 1.3-53  DFU BL 0.0-0   9c:8c:d8:cf:c6:86  127.0.0.1:8514  2020-05-19 19:17:17   0         Current
Total AP BLE devices reported:1
Note:'Status' column indicates whether information received for an AP's
    : BLE radio is 'Current' (message received in the last 10 minutes)
    : or 'OutOfDate' (message received more than last 10 minutes ago and/or AP might be down).
9c:8c:d8:cf:c6:86# show ap debug ble-table
BLE Device Table [APBs]
MAC                HW_Type   FW_Ver          Flags   Status  Radio Type  Major#  Minor#  UUID                                  Meas. Pow.  Tx_Power  Last Update  Uptime
20:4c:03:45:c6:e8  BT-AP550  DFU App 1.3-53  0x0183  LIA     Internal    0       0       4152554E-F99B-4A3B-86D0-947070693A78  -56         7         2s           23h:40m:40s
BLE Device Table [Aruba Beacons]
MAC                HW_Type   FW_Ver          Flags   Status  Batt(%)  RSSI  Major#  Minor#  UUID                                  Meas. Pow.  Tx_Power  Last Update  Uptime
20:4c:03:3e:de:24  BT-AP510  DFU App 1.3-32  0x0183  IA      ONBOARD  -87   16005   24699   4152554E-F99B-4A3B-86D0-947070693A78  -56         15        I:1239s      1h:30m:30s
20:4c:03:3e:de:26  BT-AP510  DFU App 1.3-32  0x0183  IA      ONBOARD  -84   16005   24692   4152554E-F99B-4A3B-86D0-947070693A78  -56         15        I:2s         1h:49m:0s
20:4c:03:3e:de:29  BT-AP510  DFU App 1.3-32  0x0183  IA      ONBOARD  -67   16005   24700   4152554E-F99B-4A3B-86D0-947070693A78  -56         15        I:0s         1h:55m:30s
20:4c:03:3e:de:2e  BT-AP510  DFU App 1.3-32  0x0183  IA      ONBOARD  -84   16005   24693   4152554E-F99B-4A3B-86D0-947070693A78  -56         15        I:1239s      1h:31m:0s
20:4c:03:3e:de:34  BT-AP510  DFU App 1.3-32  0x0183  IA      ONBOARD  -93   16005   24702   4152554E-F99B-4A3B-86D0-947070693A78  -56         15        I:67s        1h:28m:30s
20:4c:03:3e:de:37  BT-AP510  DFU App 1.3-32  0x0183  IA      ONBOARD  -81   16005   24696   4152554E-F99B-4A3B-86D0-947070693A78  -56         15        I:1237s      1h:32m:0s
20:4c:03:3e:de:38  BT-AP510  DFU App 1.3-32  0x0183  IA      ONBOARD  -75   16005   24691   4152554E-F99B-4A3B-86D0-947070693A78  -56         15        I:1s         2h:2m:30s
20:4c:03:3e:df:2e  ARUBA     OAD A 1.3-24    0x0001  A       --       -71   0       0                                             --          --        I:161s       30s
Beacons:8
Total BLE devices:8
Note: Battery level for LS-BT1USB devices is indicated as USB.
Note: Uptime is shown as Days hour:minute:second.
Note: Last Update is time in seconds since last heard update.
Note: Meas. Pow. is the averaged RSSI (in dBm) when the iBeacon is calibrated.
Status Flags:L:AP's local beacon; I:iBeacon; A:Beacon management capable
            :H:High power beacon; T:Asset Tag Beacon; U:Upgrade of firmware pending
            :u:Beacon management update received
Version history
Revision #:
2 of 2
Last update:
‎05-25-2020 11:48 PM
Updated by:
Labels (1)
Contributors
