This community is currently in a read-only state due to a maintenance window. For more info click here
Enterprise Domains in IAP
MVP
MVP
Q:
How many Enterprise domains URL can be configured in Instant AP RAPNG Environment?
A:
By Default all the DNS requests from a client are forwarded to the clients DNS server. So in a typical IAP deployment without VPN configuration, client DNS requests are resolved by the clients' DNS server. However, when an IAP is configured for RAPNG this behavior changes. The DNS behavior of an IAP network (SSID/wired port) configured for RAPNG is determined by the enterprise domain settings. The enterprise domain setting on the IAP defines the domains for which the DNS resolution must be forwarded to the clients' default DNS server. For instance, if the enterprise domain is configured for arubanetworks.com, then DNS resolution for hostnames in arubanetworks.com will be forwarded to the clients' default DNS server and the DNS resolution for hostnames in all other domains will be Scr-NATed to the local DNS server of the IAP.
Note: Configuring * instead of a domain name in the Enterprise domain list will forward all DNS requests to the clients' default DNS server.
NOTE: with the current version we can add up to 4 Enterprise domains URL
Configuration Output: (Test Performed on 8.6)
TACLAB-IAP315-2 (config) # internal-domains
TACLAB-IAP315-2 (domains) # domain-name abc.com
TACLAB-IAP315-2 (domains) # domain-name abc1.com
TACLAB-IAP315-2 (domains) # domain-name anc2.com
TACLAB-IAP315-2 (domains) # domain-name abc3.com
TACLAB-IAP315-2 (domains) # domain-name abc4.com -------> 5th Enterprise Domain URL
TACLAB-IAP315-2 (domains) # exit
TACLAB-IAP315-2 (config) # exit
TACLAB-IAP315-2# commit  apply
committing configuration...
Domain Name is full.
Running config output:  (IAP taking only the first 4 enterprise Domain URL)
internal-domains
domain-name abc.com
Version history
Revision #:
2 of 2
Last update:
‎07-07-2020 02:08 PM
Updated by:
Labels (1)
Contributors
