How to bring IAP behind a Mesh Point
MVP Expert
MVP Expert
How to bring up an IAP connected to a switch behind the mesh point.
IAP----Switch---MeshPortal ))))  (((( MeshPoint --- Switch --- IAP
Starting from 4.2.1.0, IAPs can be added to a cluster connected behind a mesh point.
Step1: Enable enet0-bridging on the Mesh Point.
Step2: Configure the wired port for the Mesh point and configure the switchport for enet0.
Step3: If the IAP cluster is setup on any different vlan other than VLAN1, configure enet-vlan on the Master and commit apply.
            #enet-vlan <vlan-id of IAP cluster>
            #commit apply
VC-Portal# show aps
3 Access Points
Name               IP Address     Mode    Spectrum  Clients  Type          Mesh Role  Zone  Serial #   2.4 Channel  2.4 Power (dB)  2.4 Utilization (%)  2.4 Noise Floor (dBm)  5.0 Channel  5.0 Power (dB)  5.0 Utilization (%)  5.0 Noise Floor (dBm)  Need Antenna Config  From Port  Config Id  Config Csum  Ext SSID Active  Age
VC-Portal          10.17.168.30*  access  disable   0        277(outdoor)  Portal     -     CL0041669  11           24              60(ok)               -97(good)              124+         28              6(good)              -94(good)              No                   none       5          59282        disable          1h:24m:55s
Point              10.17.168.29   access  disable   0        277(outdoor)  Point      -     CL0045217  1            30              61(ok)               -95(good)              124+         28              6(good)              -94(good)              No                   none       5          59282        disable          57m:47s
40:e3:d6:c9:d2:4a  10.17.168.28   access  disable   0        277(outdoor)  Portal     -     CL0041661  11           27              66(ok)               -94(good)              52+          23              13(good)             -97(good)              No                   eth0       5          59282        disable          46m:18s
VC-Portal#
Version history
Revision #:
2 of 2
Last update:
‎03-15-2019 01:22 PM
Updated by:
Labels (1)
Contributors
