How to disable console access on an Instant Access Point from Web UI and CLI
MVP
MVP
WLAN administrator might want to disable console access for their IAPs to avoid anyone from locally accessing it.
Starting 6.4.4.4-4.2.X.X, Instant Access point provides an option to disable console access.
From Web UI:
System -> General -> Console access -> enable/disable
From CLI:
Review the running configuration as instructed below to ensure the configuration is saved.
Once console access is disabled, when any one tries to console into any IAP in a cluster, it will throw below error.
Version history
Revision #:
2 of 2
Last update:
‎04-01-2019 07:31 PM
Updated by:
Labels (1)
Contributors
