Minimum supported version - Aruba Instant 6.5.3.0
This command enables pre-standard POE+ detector on IAP-200 Series, IAP-210 Series, IAP-220 Series, IAP-270 Series access points.
To enable:
94:b4:0f:c6:9b:f6# ap2xx-prestandard-poe-detection
To disable:
94:b4:0f:c6:9b:f6# no ap2xx-prestandard-poe-detection
Once enabling the command on the IAP and then reload it when the switch is using pre-standard or Legacy POE+.
