MAC caching for cloud guest SSID
MVP
MVP
Q:
How is the MAC caching interval determined on cloud guest based SSID ?
A:
The MAC caching duration is derived from the Session Timeout field present on splash page present under Cloud Guest option on central.
During this period, the client device does not have to re-authenticate again on the portal page.
However, once the session timeout value is reached, the re-authentication needs to be done.
So, session timeout is the maximum number of seconds allowed for the session before it should be terminated.
Version history
Revision #:
2 of 2
Last update:
‎03-15-2019 01:28 PM
Updated by:
Labels (1)
Contributors
