Troubleshooting Max Client Per AP/SSID Feature
MVP Expert
MVP Expert
Problem:
This article applies to all Instant APs running 6.5.0.0-4.3.0.0 version and higher.
"Maximum client threshold" is an option to allow maximum number of clients to associate to an AP on per radio basis. This option will not work if "Band-steering" and "client match" is set to enabled.
Diagnostics:
1. Set RF Band steering to "Balanced Band" and configure a-max clients as 1 and g-max-clients as 4
ac:a3:1e:cd:46:fc# a-max-clients Instant 1
ac:a3:1e:cd:46:fc# g-max-clients Instant 4
ac:a3:1e:cd:46:fc# show a-max-clients Instant
a-max-clients: 1
ac:a3:1e:cd:46:fc# show g-max-clients Instant
g-max-clients: 4
ac:a3:1e:cd:46:fc# show network Instant | include "Max Cl"
Max Clients Threshold               :64
ac:a3:1e:cd:46:fc# show running-config | include "teering"
band-steering-mode balance-bands
2. Now try connecting 2 dual Band clients
Expectation:
1. 1 client should connect to A_band and 1 client connects to G-band because a-max client is set to 1 and also Balanced Band is enabled.
Observed result:
Both clients connected to A-band which is contradicting "a-max-clients" configuration
ac:a3:1e:cd:46:fc# show clients
Client List
Name         IP Address     MAC Address        OS  ESSID  Access Point       Channel  Type  Role  IPv6 Address               Signal    Speed (mbps)
auto-PC      10.17.137.153  80:86:f2:80:fc:a5      Instant   ac:a3:1e:cd:46:fc  161      AN    1946  fe80::5501:adf4:5032:e082  59(good)  144(good)
Naveenk-cl1  10.17.137.139  b4:b6:76:42:55:e5      Instant   ac:a3:1e:cd:46:fc  161      AN    1946  fe80::dc6:6d53:5340:d96e   47(good)  144(good)
Number of Clients   :2
Info timestamp      :857
ac:a3:1e:cd:46:fc# show ap debug mgmt-frames
Traced 802.11 Management Frames
Timestamp        stype       SA                 DA                 BSS                signal  Misc
Jul 18 07:38:10  deauth      ac:a3:1e:54:6f:c0  0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:c0  15      - (internal only)
Jul 18 07:38:10  auth        ac:a3:1e:54:6f:c0  0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:c0  15      AP is resource constrained (seq num 2056)
Jul 18 07:38:10  auth        0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:c0  ac:a3:1e:54:6f:c0  0       -
Jul 18 07:38:10  auth        ac:a3:1e:54:6f:c0  0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:c0  15      AP is resource constrained (seq num 0)
Jul 18 07:38:09  deauth      ac:a3:1e:54:6f:c0  0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:c0  15      - (internal only)
Jul 18 07:38:09  auth        ac:a3:1e:54:6f:c0  0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:c0  15      AP is resource constrained (seq num 2056)
Jul 18 07:38:09  auth        0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:c0  ac:a3:1e:54:6f:c0  0       -
Jul 18 07:38:07  assoc-resp  ac:a3:1e:54:6f:d0  0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:d0  15      AP is resource constrained-Max Clients Associated
Jul 18 07:38:07  assoc-req   0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:d0  ac:a3:1e:54:6f:d0  48      -
Jul 18 07:38:07  auth        ac:a3:1e:54:6f:d0  0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:d0  15      Success (seq num 2056)
Jul 18 07:38:07  auth        0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:d0  ac:a3:1e:54:6f:d0  0       -
Jul 18 07:38:07  assoc-req   0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:d0  ac:a3:1e:54:6f:d0  50      -
Jul 18 07:38:07  assoc-req   0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:d0  ac:a3:1e:54:6f:d0  49      -
Jul 18 07:38:06  assoc-resp  ac:a3:1e:54:6f:d0  0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:d0  15      AP is resource constrained-Max Clients Associated
Jul 18 07:38:06  assoc-req   0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:d0  ac:a3:1e:54:6f:d0  49      -
Jul 18 07:38:06  auth        ac:a3:1e:54:6f:d0  0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:d0  15      Success (seq num 2056)
Jul 18 07:38:06  auth        0e:00:2e:78:7c:eb  ac:a3:1e:54:6f:d0  ac:a3:1e:54:6f:d0  0       -
Solution
3. Now try increasing the user limit for A-band and check whether association is successful for 3rd client
Expectation:
Since we have increased user limit for A_band we expect clients to connect
Observed result:
Client connection to Both Band failed due to Max constraint
ac:a3:1e:cd:46:fc# a-max-clients Instant 2
a-max-clients: 2
g-max-clients: 4
ac:a3:1e:cd:46:fc#
ac:a3:1e:cd:46:fc#
Client List
auto-PC      10.17.137.153  80:86:f2:80:fc:a5      Instant   ac:a3:1e:cd:46:fc  161      AN    Instant  fe80::5501:adf4:5032:e082  59(good)  144(good)
Naveenk-cl1  10.17.137.139  b4:b6:76:42:55:e5      Instant   ac:a3:1e:cd:46:fc  161      AN    Instant fe80::dc6:6d53:5340:d96e   47(good)  144(good)
Info timestamp      :1089
ac:a3:1e:cd:46:fc# show ap association
The phy column shows client's operational capabilities for current association
Flags: A: Active, B: Band Steerable, H: Hotspot(802.11u) client, K: 802.11K client, M: Mu beam formee, R: 802.11R client, W: WMM client, w: 802.11w client V: 802.11v BSS trans capable
PHY Details: HT   : High throughput;      20: 20MHz;  40: 40MHz; t: turbo-rates (256-QAM)
             VHT  : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
             <n>ss: <n> spatial streams
Association Table
Name               bssid              mac                auth  assoc  aid  l-int  essid  vlan-id  tunnel-id  phy             assoc. time  num assoc  Flags  DataReady
ac:a3:1e:cd:46:fc  ac:a3:1e:54:6f:d0  80:86:f2:80:fc:a5  y     y      1    250    Instant        0x0        a-HT-20sgi-2ss  7m:46s       1          W      Yes (Implicit)
ac:a3:1e:cd:46:fc  ac:a3:1e:54:6f:d0  b4:b6:76:42:55:e5  y     y      2    100    Instant   1        0x0        a-HT-20sgi-2ss  7m:22s       1          W      Yes (Implicit)
Num Clients:2
Jul 18 07:41:56  deauth      ac:a3:1e:54:6f:c0  0e:00:32:f8:ef:87  ac:a3:1e:54:6f:c0  15      - (internal only)
Jul 18 07:41:56  auth        ac:a3:1e:54:6f:c0  0e:00:32:f8:ef:87  ac:a3:1e:54:6f:c0  15      AP is resource constrained (seq num 2056)
Jul 18 07:41:56  auth        0e:00:32:f8:ef:87  ac:a3:1e:54:6f:c0  ac:a3:1e:54:6f:c0  0       -
Jul 18 07:41:55  deauth      ac:a3:1e:54:6f:c0  0e:00:32:f8:ef:87  ac:a3:1e:54:6f:c0  15      - (internal only)
Jul 18 07:41:55  auth        ac:a3:1e:54:6f:c0  0e:00:32:f8:ef:87  ac:a3:1e:54:6f:c0  15      AP is resource constrained (seq num 2056)
Jul 18 07:41:55  auth        0e:00:32:f8:ef:87  ac:a3:1e:54:6f:c0  ac:a3:1e:54:6f:c0  0       -
Jul 18 07:41:55  auth        ac:a3:1e:54:6f:c0  0e:00:32:f8:ef:87  ac:a3:1e:54:6f:c0  15      AP is resource constrained (seq num 0)
Jul 18 07:41:54  assoc-resp  ac:a3:1e:54:6f:d0  0e:00:32:f8:ef:87  ac:a3:1e:54:6f:d0  15      AP is resource constrained-Max Clients Associated
Jul 18 07:41:54  assoc-req   0e:00:32:f8:ef:87  ac:a3:1e:54:6f:d0  ac:a3:1e:54:6f:d0  55      -
Jul 18 07:41:54  auth        ac:a3:1e:54:6f:d0  0e:00:32:f8:ef:87  ac:a3:1e:54:6f:d0  15      Success (seq num 2056)
Jul 18 07:41:54  auth        0e:00:32:f8:ef:87  ac:a3:1e:54:6f:d0  ac:a3:1e:54:6f:d0  0       -
Jul 18 07:41:54  assoc-req   0e:00:32:f8:ef:87  ac:a3:1e:54:6f:d0  ac:a3:1e:54:6f:d0  56      -
Jul 18 07:41:54  auth        ac:a3:1e:54:6f:d0  0e:00:32:f8:ef:87  ac:a3:1e:54:6f:d0  15      Success (seq num 0)
Jul 18 07:41:54  assoc-req   0e:00:32:f8:ef:87  ac:a3:1e:54:6f:d0  ac:a3:1e:54:6f:d0  54      -
4. Now try reverting the configuration Back to "prefer-Ghz" which is the default configuratyion and try association 3rd clients
Expectation:
1. Client should associate successfully to G-band now (since a-max-clients is configured with 2 clients and already 2 clints associated to A-band)
Observed result:
Even after we move the cofniguration to "prefer-5Ghz" and when we have free slots on G-band we send assoc failure when clients triees to connect
 band-steering-mode prefer-5ghz
ac:a3:1e:cd:46:fc#
ac:a3:1e:cd:46:fc#
Client List
auto-PC      10.17.137.153  80:86:f2:80:fc:a5      1946   ac:a3:1e:cd:46:fc  161      AN    1946  fe80::5501:adf4:5032:e082  59(good)  144(good)
Naveenk-cl1  10.17.137.139  b4:b6:76:42:55:e5      1946   ac:a3:1e:cd:46:fc  161      AN    1946  fe80::dc6:6d53:5340:d96e   47(good)  144(good)
Info timestamp      :1354
ac:a3:1e:cd:46:fc# show a-max-clients 1946
a-max-clients: 2
ac:a3:1e:cd:46:fc# show g-max-clients 1946
g-max-clients: 4
ac:a3:1e:cd:46:fc# show network 1946 | include "Max Cl"
Jul 18 07:49:13  deauth      ac:a3:1e:54:6f:c0  b4:b6:76:41:fe:9c  ac:a3:1e:54:6f:c0  15      - (internal only)
Jul 18 07:49:13  auth        ac:a3:1e:54:6f:c0  b4:b6:76:41:fe:9c  ac:a3:1e:54:6f:c0  15      AP is resource constrained (seq num 2056)
Jul 18 07:49:13  auth        b4:b6:76:41:fe:9c  ac:a3:1e:54:6f:c0  ac:a3:1e:54:6f:c0  0       -
Jul 18 07:49:12  deauth      ac:a3:1e:54:6f:c0  b4:b6:76:41:fe:9c  ac:a3:1e:54:6f:c0  15      - (internal only)
Jul 18 07:49:12  auth        ac:a3:1e:54:6f:c0  b4:b6:76:41:fe:9c  ac:a3:1e:54:6f:c0  15      AP is resource constrained (seq num 2056)
Jul 18 07:49:12  auth        b4:b6:76:41:fe:9c  ac:a3:1e:54:6f:c0  ac:a3:1e:54:6f:c0  0       -
Jul 18 07:49:11  deauth      ac:a3:1e:54:6f:c0  b4:b6:76:41:fe:9c  ac:a3:1e:54:6f:c0  15      - (internal only)
Jul 18 07:49:11  auth        ac:a3:1e:54:6f:c0  b4:b6:76:41:fe:9c  ac:a3:1e:54:6f:c0  15      AP is resource constrained (seq num 2056)
Jul 18 07:49:11  auth        b4:b6:76:41:fe:9c  ac:a3:1e:54:6f:c0  ac:a3:1e:54:6f:c0  0       -
Jul 18 07:49:09  assoc-resp  ac:a3:1e:54:6f:d0  b4:b6:76:41:fe:9c  ac:a3:1e:54:6f:d0  15      AP is resource constrained-Max Clients Associated
Jul 18 07:49:09  assoc-req   b4:b6:76:41:fe:9c  ac:a3:1e:54:6f:d0  ac:a3:1e:54:6f:d0  59      -
Jul 18 07:49:09  auth        ac:a3:1e:54:6f:d0  b4:b6:76:41:fe:9c  ac:a3:1e:54:6f:d0  15      Success (seq num 2056)
Jul 18 07:49:09  auth        b4:b6:76:41:fe:9c  ac:a3:1e:54:6f:d0  ac:a3:1e:54:6f:d0  0       -
Jul 18 07:49:09  assoc-req   b4:b6:76:41:fe:9c  ac:a3:1e:54:6f:d0  ac:a3:1e:54:6f:d0  60      -
Note: This feature is to be used with BandSteering and ClientMatch disabled.
Version history
Revision #:
2 of 2
Last update:
‎03-17-2019 09:58 AM
Updated by:
Labels (1)
Contributors
