What is cluster security and how does it guarantee secure communication?
MVP Expert
MVP Expert
How are the control plane messages exchanged between Master and Slaves secured in an Aruba Instant deployment?
Starting 4.3.1.0, cluster security is used to provide secure control plane communication between IAP cluster nodes.
Control plane messages between cluster members like configuration, cluster join and related messages are secured using this protocol.
It runs on UDP port 4434 and uses DTLS protocol to secure messages.
A DTLS connection is established between communicating peers / IAPs.
  • Mutual authentication is done between the  IAPs using device certificate.
  • Additionally peer MAC address validation against "AP whitelist" can be enabled in the configuration.
  • Control plane messages between cluster members are transmitted securely using the DTLS connection established.
    • ECDHE-RSA-AES128-SHA256 is the cipher suite used for the DTLS connection.
CLI
WebUI
show cluster-security
show cluster-security connections
show cluster-security peers
show cluster-security stats
show log papi handler
Version history
Revision #:
2 of 2
Last update:
‎03-31-2019 10:47 AM
Updated by:
Labels (1)
Contributors
