Occasional Contributor I
Re: AP-303H clients are not connecting to 5GHz when Band set to All
Colin.
Per previous post.  The device is behaving as expected, but only after about 15 minutes of up time.  I have never seen this behavior on other Aruba AP's.  I'm going to get a hold of a power brick and see if that makes a difference.
I'm simply using the speed test app on an IOS device for reference.  After 15 minutes, the device switches over to the 5Ghz and I get the full available throughput of 330Mbps.  The behavior is the same whether IOS or Windows PC.
It's not a big deal now that I know what to expect.
You should open a TAC case so that they can examine your settings and attempt to replicate what you are observing. There is much info not in this thread that will affect what you are doing like client type, channel width, co-channel interference and density of access points.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
