AP105 not able to join Aruba620 Controller
We have Master-Local(version 6.4.2.5) setup, two 105 APs are not able to join the controller, we processed RMA, brand new APs are also having the same problem.
logs as below.
e 7172 error Unexpected result code CONFIG_ERR.
Dec 6 14:08:12 :305004: <ERRS> |stm| AP ac:a3:1e:cf:cf:62: ap regulatory-domain-profile "default" is invalid.
Dec 6 14:08:12 :305027: <ERRS> |stm| AP ac:a3:1e:cf:cf:62: No valid instances of required profile "ap regulatory-domain-profile"
Dec 6 14:08:24 :399838: <WARN> |nanny| Resource 'Controlpath CPU' has exceeded 45% threshold (actual:61%).
MVP Expert
Re: AP105 not able to join Aruba620 Controller
What is the exact type of the AP's? IAP-105-XX or AP-105?
Cheers, Frank
AirHeads MVP Expert | Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
its AP-105 DBDC 2x2:2 802.11agn AP
If you processed an RMA, you should also open a TAC case.  The message suggests a regulatory issue with your configuration, but I cannot be sure with a couple lines of logs.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Yes, we have the TAC case, Initially, TAC suspects the AP fault after testing connecting not working AP to working AP port as we see the same issue.
Now we received two new APs they are also behaving same as previous, I have added more logs from the controller.
Dec 7 09:19:47 :305004: <ERRS> |stm| AP ac:a3:1e:cf:cf:67: ap regulatory-domain-profile "default" is invalid.
Dec 7 09:19:47 :305027: <ERRS> |stm| AP ac:a3:1e:cf:cf:67: No valid instances of required profile "ap regulatory-domain-profile"
Dec 7 09:20:31 :303022: <WARN> |AP ac:a3:1e:cf:cf:62@10.158.16.135 nanny| Reboot Reason: AP rebooted Fri Dec 31 16:01:48 PST 1999: SAPD: Reboot after image upgrade
Dec 7 09:20:43 :399838: <WARN> |nanny| Resource 'Controlpath CPU' has dropped below 45% threshold (actual:12%).
Dec 7 09:20:50 :305004: <ERRS> |stm| AP ac:a3:1e:cf:cf:62: ap regulatory-domain-profile "default" is invalid.
Dec 7 09:20:50 :305027: <ERRS> |stm| AP ac:a3:1e:cf:cf:62: No valid instances of required profile "ap regulatory-domain-profile"
Dec 7 09:20:50 :311020: <ERRS> |AP ac:a3:1e:cf:cf:62@10.158.16.135 sapd| An internal system error has occurred at file sapd_msg.c function sapd_hello_cb line 7172 error Unexpected result code CONFIG_ERR.
Dec 7 09:22:35 :303022: <WARN> |AP ac:a3:1e:cf:cf:62@10.158.16.135 nanny| Reboot Reason: AP rebooted Fri Dec 31 16:01:25 PST 1999; SAPD: Reboot after image upgrade failed: 32512
Dec 7 09:22:53 :305004: <ERRS> |stm| AP ac:a3:1e:cf:cf:67: ap regulatory-domain-profile "default" is invalid.
Dec 7 09:22:53 :305027: <ERRS> |stm| AP ac:a3:1e:cf:cf:67: No valid instances of required profile "ap regulatory-domain-profile"
Dec 7 09:22:54 :305004: <ERRS> |stm| AP ac:a3:1e:cf:cf:62: ap regulatory-domain-profile "default" is invalid.
Dec 7 09:22:54 :305027: <ERRS> |stm| AP ac:a3:1e:cf:cf:62: No valid instances of required profile "ap regulatory-domain-profile"
Dec 7 09:22:54 :311020: <ERRS> |AP ac:a3:1e:cf:cf:62@10.158.16.135 sapd| An internal system error has occurred at file sapd_msg.c function sapd_hello_cb line 7172 error Unexpected result code CONFIG_ERR.
Miss to add one more point, we tried rebooting the controller still no luck.
MVP Guru
What is the regulatory domain of the controller and of the AP? Have you made any changes to the default profile of the regulatory domain?
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
After changing the default AP group regulatory domain on Master controller issue got resolved.
MVP Expert
thanks for the update
Cheers, Frank
Its AP-105
