Highlighted
Valued Contributor II
Re: Add IAP to existing VC
Hi friend,
Let me get some clarity on this.
do you have IAP 105 as a master already ? or trying to bring up both IAPs ?
If you have Master already, please enable Auto join in the master.
please share the output of the following, run these commands on IAP 103
1. show election
2. debug-master-beacon
we can fix this issue once we go through the above out puts
Cheers,
Venu Puduchery,
Highlighted
Thanks for your help.
The IAP 105 is set as Master and it is configured as Enabled in "System -> Auto join mode".
I just reset the IAP 103 device.
Access to the "instant" SSID, change the Country Code (same as the IAP 105).
I see the IP address that it takes from DHCP (same range as the IAP 105).
Connect again to the IAP 105 (master) SSID and access to the IAP 103 from console:
# show election
State        : Master
master_beacon   : sent=492 rcvd=0
hierarchy_beacon: sent=0 rcvd=0
hierarchy_ack   : sent=0 rcvd=0
beacon_req      : sent=0 rcvd=0
beacon_resp     : sent=0 rcvd=0
election wait   : 0
timer slow      : 0
master high cpu : 0
ap cpu usage    : 0
Slave->Pot-Master : 0 time
Pot-master->Master: 0 time
Pot-master->Slave : 0 time
last spoof arp rcvd: 0
last spoof mac: 00:00:00:00:00:00
last beacon received ticks: 0
uplink flap count         : 0
max beacon miss ticks     : 0
hierarchy mode            : 0
last hierarchy beacon received ticks: 0
provisioned master denied : 0
# debug-master-beacon
(nothin in the output)
 The IAP 103 can ping to IAP 105:
# ping 192.168.2.232
Press 'q' to abort.
PING 192.168.2.232 (192.168.2.232): 56 data bytes
64 bytes from 192.168.2.232: icmp_seq=0 ttl=64 time=2.0 ms
64 bytes from 192.168.2.232: icmp_seq=1 ttl=64 time=0.5 ms
64 bytes from 192.168.2.232: icmp_seq=2 ttl=64 time=0.5 ms
64 bytes from 192.168.2.232: icmp_seq=3 ttl=64 time=0.5 ms
64 bytes from 192.168.2.232: icmp_seq=4 ttl=64 time=0.5 ms
--- 192.168.2.232 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 0.5/0.8/2.0 ms
 And to the VC:
# ping 192.168.2.239
Press 'q' to abort.
PING 192.168.2.239 (192.168.2.239): 56 data bytes
64 bytes from 192.168.2.239: icmp_seq=0 ttl=64 time=2.1 ms
64 bytes from 192.168.2.239: icmp_seq=1 ttl=64 time=0.5 ms
64 bytes from 192.168.2.239: icmp_seq=2 ttl=64 time=0.5 ms
64 bytes from 192.168.2.239: icmp_seq=3 ttl=64 time=0.5 ms
64 bytes from 192.168.2.239: icmp_seq=4 ttl=64 time=0.5 ms
--- 192.168.2.239 ping statistics ---
round-trip min/avg/max = 0.5/0.8/2.1 ms
Need I configure something else?
Thanks and best regards.
Highlighted
The output clearly saying that. IAP 103 is not receiving Master beacons hence it is assuming itself as the Master. we have figure out why it is not able to receive the Master beacon from IAP 105.
Master beacon traffic is L2 traffic hence we have to find the reason why L2 traffic is not getting exchanged.
Console IAP 105 (MAster) and run the same commands and see if you get some hint.
If not, please open a case with TAC.
Cheers,
Venu Puduchery,
Highlighted
Thanks again,
This is the commands in the IAP 105:
# show election
State        : Master
master_beacon   : sent=0 rcvd=542220
election wait   : 0
timer slow      : 0
master high cpu : 0
ap cpu usage    : 9
hierarchy mode            : 0
Need I force the IAP 103 to be slave device?
Thansk for you help.
Regards.
Highlighted
Trusted Contributor I
in principle you should have to.
if you can i would save the config, reset both devices to factory default and start from there.
if you can't then again go over the basics, firmware version, l2 connectivity, auto add members, no fixed master, ...
View solution in original post
Highlighted
Thanks!
I did it and it works.
I reset the IAP105 device, configure the IAP 103 as master, and when I connect the reseted 105 it join automatically.
Regards.
Highlighted
What is the version running on the 105?
