Air monitoring AP207- Get Inactive "I" Flag
we Try to depoly AP as a AM mode but every time get I flag we make a basic trubleshooting "change static ip , factory reset , change switch port and change "but didn't help.
note that ap is 207
cntr is 7030 on 6.5.4.6.
MVP Guru
Re: Air monitoring AP207- Get Inactive "I" Flag
Are your Radio Profiles set to am-mode?
rf dot11a-radio-profile "dot11a-AM"
    mode am-mode
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
yes.profile set as am-mode not ap-mode
MVP Guru
Do you want to share your configuration as its difficult to troubleshoot with minimal information. What is the regulatory domain of the APs? Have you check the logs for any warnings or errors regarding to the AM's?
i have bacup configuration but before create ids/ips . will it help ?
