Highlighted
Airwave doesn't know iap325
Airwave doesn't know our iap325's
Everytime i poll or try to discover our iap:
Unknown SysObjectID ".1.3.6.1.4.1.14823.1.2.78", remaining as generic device type.
but :
in mibs:
IAP-3251.3.6.1.4.1.14823.1.2.78
Highlighted
MVP Expert
Re: Airwave doesn't know iap325
What version are you running at Airwave and the IAP's?
Willem Bargeman ACMX#935 | ACCX #822
Please give me kudos if my post was useful!
If your issue is solved mark the post as solution!
Highlighted
MVP Expert
How you are adding IAP device to Airwave? We have to proivde airwave IP details in IP under system sectoion.
We can not add IAP as SNMP devices in Airwave
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
airwave 8.2.8.2 (the last but i've tried with version 8.2.6.1 and 8.2.8.1
AIP325 8.3.0.6_69128 but i've tried with 6.5.4.11 and 6.5.4.3
Highlighted
i've tried with discover mode but failure ...
i've tried with add device mode but the configuration of the aip is wrong cause the message  Unknown SysObjectID ".1.3.6.1.4.1.14823.1.2.78"
Other pb, there is no template for this equipment (cause airwave think it's and generic equipement
Airwave communicates with the iap, he has found the firmaware version but cannot understand the answer for the model
{ GetResponse(38) R=26854121 system.sysObjectID.0=E:14823.1.2.7}
{ GetResponse(73) R=940935988 system.sysDescr.0="ArubaOS (MODEL: 325), Version 8.3.0.6-8.3
Highlighted
MVP Guru
Have you added the AirWave IP under the VC as opposed as a generic device? This will integrate the VC and IAPs into AirWave correctly. If you check the AirWave 8.2.8.2 supported devices documentation, it only lists ArubaOS 8.3.0.0, 8.3.0.1, 8.3.0.2, and 8.3.0.3 as supported. So I suspect you will need to wait for a later release of AirWave to support 8.3.0.6.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Highlighted
Did this get resolved as i see similar with a 325 as well.
