Aruba 305 APs falling to All Air Monitors Group
  • 1.  Aruba 305 APs falling to All Air Monitors Group
    Posted Jan 08, 2020 05:06 AM
    am doing a new installation ..All the APs are joining to All Air Monitors Group, so am not able to broadcast my SSID
    please help
    re,
    Anvar
  • 2.  RE: Aruba 305 APs falling to All Air Monitors Group
    MVP EXPERT
    Posted Jan 08, 2020 05:19 AM
    Have you provisioned the APs to a group which isn't configured to use Air Monitors? What do is the AP Mode which the dot11a and dot11g radio profiles configured as?
    (Aruba7030) #show rf dot11a-radio-profile default
    802.11a radio profile "default"
    Parameter                                      Value
    Radio enable                                   Enabled
    Mode                                           ap-mode
  • 3.  RE: Aruba 305 APs falling to All Air Monitors Group
    Posted Jan 08, 2020 05:30 AM
    please find attached show command output
    re,
    anvar
  • 4.  RE: Aruba 305 APs falling to All Air Monitors Group
    MVP EXPERT
    Posted Jan 08, 2020 05:34 AM
    Can you provide the output of 'show ap active'.
    I'm assuming the box has licenses, the APs have the correct reg domain etc. Is there any profile errors 'show profile-errors'.
  • 5.  RE: Aruba 305 APs falling to All Air Monitors Group
    Posted Jan 08, 2020 05:39 AM
    attached both ...
  • 6.  RE: Aruba 305 APs falling to All Air Monitors Group
    MVP EXPERT
    Posted Jan 08, 2020 05:43 AM
    What is the regulatory domain of the controller? Do you have licenses?
  • 7.  RE: Aruba 305 APs falling to All Air Monitors Group
    Posted Jan 08, 2020 05:44 AM
    Domain is Saudi Arabia ...
    yes i do have license for 144 AP ..its just installed today
    re,
    Anvar
  • 8.  RE: Aruba 305 APs falling to All Air Monitors Group
    Posted Jan 08, 2020 05:49 AM
    the firmware is
    6.5.1.4
    will it be a problem
    re
    Anvar
  • 9.  RE: Aruba 305 APs falling to All Air Monitors Group
    MVP EXPERT
    Posted Jan 08, 2020 05:48 AM
    Can you confirm the DRT installed on the Controller?
    #show switches regulatory
  • 10.  RE: Aruba 305 APs falling to All Air Monitors Group
    Posted Jan 08, 2020 05:51 AM
    attached regualtory details
  • 11.  RE: Aruba 305 APs falling to All Air Monitors Group
    MVP EXPERT
    Posted Jan 08, 2020 05:53 AM
    ** EDIT **
    It looks like even in DRT release DRT1.0_72277 the AP305 is NOT supported in Saudi Arabia.
    To view the approved channels for this country domain, use the following CLI command:
    show ap allowed-channels country-code <country-code> ap-type <ap-type>
  • 12.  RE: Aruba 305 APs falling to All Air Monitors Group
    Posted Jan 09, 2020 03:28 AM
    Dear i upgrded the firmware to 6.5.4.15
    so its okay now ....but i have another issues which the clients can not access Network ...they are getting IP Address correctly ,,but no access to network..no ping to Gateway
    the gateway is Core Swicth
    re
    Anvar
