MVP Guru
Re: Aruba 305 APs falling to All Air Monitors Group
** EDIT **
It looks like even in DRT release DRT1.0_72277 the AP305 is NOT supported in Saudi Arabia.
To view the approved channels for this country domain, use the following CLI command:
show ap allowed-channels country-code <country-code> ap-type <ap-type>
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Dear i upgrded the firmware to 6.5.4.15
so its okay now ....but i have another issues which the clients can not access Network ...they are getting IP Address correctly ,,but no access to network..no ping to Gateway
the gateway is Core Swicth
re
Anvar
