Highlighted
Aruba IAP 207 Bridge issues
we have two IAP207. One is used as a normal AP and the other is used as a bridge to connect other pc via cable.
Our problem is, that the bridge sometime don't connect after lost the connection.We need to reboot the normal AP to make the bridge connect again.
An other problem is, that the bridge takes a very long time to connect. Sometimes up to 30 minutes.
What could be the problem?
Highlighted
Community Administrator
Re: Aruba IAP 207 Bridge issues
