Highlighted
Aruba IAP315 not joining cluster/fully booting
Hello all,
We are in the process of changing all of our access points to IAPs and have been configuring them. We had successfully confgured multiple IAP 305s and a 304 by having them boot with DHCP and then assigning a static address later one, they were all in the same vlan and broadcasting the same SSIDs.
On the 315, I changed the address and followed the same steps as with the other ones but the IAP will not show up inside the virtual controller. I can type in the address of the 315 into a browser and it will route me to the GUI of the virtual controller but the AP will not be listed with the cluster. The system status light is green/flashing so I think the boot is finished.
I tried to upgrade the firmware on all the IAPs and the result is the same.
Does anyone know what might be causing this?
Accepted Solutions
Highlighted
Re: Aruba IAP315 not joining cluster/fully booting
I upgraded to master IAP305 to 8.3.0.6 and now they are working and seeing eachother.
Thank you
View solution in original post
All Replies
Highlighted
What version of Instant is your existing cluster?
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
6.5.4.8_65873 Ursa
One of the 315s was on 6.5.4.3 Hercules and the other 8.3.0.6 Hercules.
Thanks for the quick reply.
Highlighted
Did you try to downgrade them both to 6.5.4.8?
Highlighted
Thank you
