Occasional Contributor I
Re: Aruba Instant and iPads
I opened a support case, and support have given me some commands to run, when the problem occurs.
The problem is that it hasn't oocured again since I made a change to the WIP settings to turn of containment for both wired and wireless. Not sure why this would be affecting the ipads?
Can you tell me if I am creating a hugh security risk by doing this?
 I cannot tell you why it has not happened, or if turning off containment really solves the issue.  Please communicate your findings to support so that they can analyze, since they have your tech support data.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
@cjoseph wrote:
Instant aps do not support OKC.
All available rates should be advertised by default unless they have been changed.
An SSID is broadcast by default unless it is manually hidden.
If an i-device disconnects after 20 minutes of inactivity it should just reconnect and not be held off the network for 15 minutes.
Please open a support case so we can get to the bottom of this.
Do you know if it is supported in 6.2.x version of Instants?
ACCP, ACCX #817, ACMP, ACMX #294
Is that still fact?
Thanks a lot!
Valued Contributor I
IAP does not support OKC -- yet.   Keep an eye out for v.4.0 over the next week or so.  OKC support is being added in that release.
Thanks a lot!
