RLB
Contributor I
Re: Beacons and IAP
One question that I am not sure was answered was whether the monitoring/management of USB beacons can be done with a network of IAPs or only Campus APs...thanks
Randy
Re: Beacons and IAP
Currently, campus APs. Instant support is coming very soon.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
RLB
Contributor I
Re: Beacons and IAP
Thanks Tim...appreciate the expeditious response, one last question if I may on the subject.  Are there any known performance or interfernce issues using USB beacons on AP225 (usb on backside of chasis) vs AP215 (top of chasis).  If so is there any recommendation to use AP215 vs AP225...
Thanks again...
Randy B.
Re: Beacons and IAP
No. You shouldn't see any interference in either situation.
tim
RLB
Contributor I
Re: Beacons and IAP
Thanks Much Tim...
Randy
