This community is currently in a read-only state due to a maintenance window. For more info click here
Highlighted
MVP Guru
Re: CP doesn't work in IAP207
Apologies, HTTP is only supported when using an External Captive Portal. If you wish to use the internal portal, then a certificate will be required.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
View solution in original post
