Cannot connect to AP535 with default credentials. LED status - Red
This thread has been viewed 22 times
  • 1.  Cannot connect to AP535 with default credentials. LED status - Red
    Posted Oct 30, 2019 06:32 AM
    Hello everyone,
    I work in a distributor company and was given a demo AP535 access point for testing/lab purposes. When i first connected it to the ethernet cable i went to the Web-GUI and it asked me to upload the firmware. I have done it, uploaded the Scorpio version of OS. Seemed like it upgraded it fine, but after the rebooting the system status LED become Red and when I try to enter the configuration menu it says that the default admin/admin credentials are incorrect.
    What could be the reason of this? Could it be because I connected it to the VoIP cable of the company(because it has PoE). Please assist me to solve the issue
  • 2.  RE: Cannot connect to AP535 with default credentials. LED status - Red
    Posted Oct 30, 2019 06:55 AM
    I believe it was changed in Instant OS 8.5.0.0.  The password is now the serial number of the AP.
    https://www.arubanetworks.com/techdocs/Instant%2085xx_RN_WebHelp/Default.htm#releasenotes/features/features85x.htm%3FTocPath%3D_____2
  • 3.  RE: Cannot connect to AP535 with default credentials. LED status - Red
    Posted Oct 30, 2019 06:56 AM
    usename: admin
    password: key in the ap serial number
  • 4.  RE: Cannot connect to AP535 with default credentials. LED status - Red
    Posted Oct 30, 2019 08:24 AM
    Ok, thank you!
