Highlighted
Contributor I
Configure LACP for the Wireless AP
Dear All
Can I configure the wireless AP port for the LACP to the PoE Switch. If Yes please guidance and I new in Aruba AP.
Controller Firmware: ArubaOS 8.3.0.6
AP Model: Aruba 345
Accepted Solutions
Highlighted
Frequent Contributor I
All Replies
Highlighted
Re: Configure LACP for the Wireless AP
Configure the switch ports to Lacp trunk and connect both cables to the ap. The AP knows when booting there is a lacp trunk. I think you can also config it manual but I think this is mutch easyer
Highlighted
Contributor I
Hi Expert
Thanks for the explanation and how should I verify the LACP Trunk on the AP side.
Highlighted
