Highlighted
Re: Configuring Instant
I had to use IE as Chrome wouldn't open the webpage!
Highlighted
What is the default account and password for this version?
i reset my ap,but i don't know account and password
Highlighted
MVP Expert
Which version? In the past it was admin/admin. Since 8.5 this is changed.
From the release notes:
New Default Management UI Password on Instant
Starting from Instant 8.5.0.0, the default management password to login to the local Instant WebUI, SSH, or Console is changed to the Serial Number
of the Instant AP. In a cluster setup, you may choose to enter the Serial Number of any of the APs in the cluster as the default login password. This
change applies to any AP in its factory default state running Instant 8.5.0.0 or a later version.
https://support.hpe.com/hpsc/doc/public/display?docId=a00072926en_us
Willem Bargeman ACMX#935 | ACCX #822
Please give me kudos if my post was useful!
If your issue is solved mark the post as solution!
