Controller based access point
  • 1.  Controller based access point
    Posted May 08, 2019 06:21 AM
    We have a building and we are looking to deploy 200 access point with controller which should support 2.4 and 5 ghz with 450mbps speed. Could you please suggest a product for this kind of setup.
  • 2.  RE: Controller based access point
    Posted May 08, 2019 06:34 AM
    To answer your question literally, the Aruba 7200 Datasheet with supported AP Matrix is here:  https://www.arubanetworks.com/assets/ds/DS_7200Series.pdf
    I encourage contact your local Aruba sales person, to ensure that your deployment is planned correctly, because number of access points is only one of a number of factors in your deployment.
  • 3.  RE: Controller based access point
    Posted May 08, 2019 06:51 AM
    is there any other solution like Unifi access point with controller software.
  • 4.  RE: Controller based access point
    Posted May 08, 2019 07:14 AM
    Please be specific.  Do you want Aruba Products or Unifi products?
  • 5.  RE: Controller based access point
    Posted May 08, 2019 07:18 AM
    we want aruba products If i use 7205 controller which ap is best for this setup. we are looking for 200 ap deployment in the building
  • 6.  RE: Controller based access point
    Posted May 08, 2019 07:30 AM
    The best product for Aruba Controllers would be Aruba access points,  because they are designed for each other and tested together.  Is there an advantage to mixing access points and controllers from different manufacturers?
  • 7.  RE: Controller based access point
    Posted May 08, 2019 07:46 AM
    recommend the product name for controller and ap ...
  • 8.  RE: Controller based access point
    Posted May 08, 2019 07:53 AM
    You should talk to an Aruba Value Added Reseller to find out what products are best for your setup.  There are a number of choices you could make based on what you want to accomplish.
  • 9.  RE: Controller based access point
    Posted May 08, 2019 06:52 AM
    I have the same question... thank You
