Controller internal Captive Portal redirection issue
I have Aruba 7005 controller with AOS 6.5.1.4 set as the Standalone controller, 3 SSIDs Corp, and Mobile working as expected, however, Guest is not redirecting the correct URL, I have few more Standalone Controller(AOS 6.5.3.6) which are working fine.
Not working  is redirecting to
:https://xx.xx.xx.xx/cgi-bin/login?profile=local_guest_db
While working controller is redirecting to https://xx.xx.xx.xx/upload/custom/local_guest_db/index.html
I manually set the working URL in CP profile still not working,
Please let me know where I am doing wrong.
Configuration on both controller Identical except AOS and VLANs.
Re: Controller internal Captive Portal redirection issue
We should focus on the controller that is not working.  What is the captive portal authentication profile configuration for the not-working controller?
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Please find  find details below:
Captive Portal Authentication Profile "local_guest_db-CP-Profile"
Parameter Value
Default Role AN-ESI-Guest-Role
Default Guest Role guest
Server Group Local Internal dB
Redirect Pause 10 sec
User Login Enabled
Guest Login Disabled
Logout popup window Enabled
Use HTTP for authentication Disabled
Logon wait minimum wait 5 sec
Logon wait maximum wait 10 sec
logon wait CPU utilization threshold 60 %
Max Authentication failures 0
Show FQDN Disabled
Authentication Protocol PAP
Login page /upload/custom/local_guest_db/index.html
Welcome page /auth/welcome.html
Show Welcome Page Yes
Add switch IP address in the redirection URL Disabled
Adding user vlan in redirection URL Disabled
Add a controller interface in the redirection URL N/A
Allow only one active user session Disabled
White List N/A
Black List N/A
Show the acceptable use policy page Disabled
User idle timeout 3600 sec
Redirect URL N/A
Bypass Apple Captive Network Assistant Disabled
URL Hash Key N/A
Why is the login page "Login page /upload/custom/local_guest_db/index.html" ?
Where we have uploaded .svg, .css and index.html files
Can you reach the page https://x.x.x.x/upload/custom/local_guest_db/index.html ?
If I manually enter this URL in browser it works, if I test View CaptivePortal  under Management > Captive Portal > Customize Login Page  selecting local_guest_db profile its redirecting to the https://x.x.x.x/cgi-bin/login?profile=local_guest_db URL and getting blank page
sorry, I missed the correct information to mention.
If I manually enter URL - "https://x.x.x.x/upload/custom/local_guest_db/index.html" in the browser it works,
If end user connects Guest SSID and tries to browse the internet it's redirecting to the "https://x.x.x.x/cgi-bin/login?profile=local_guest_db".
same result if I do testing in the controller
MVP Guru
Is your initial role correct? i.e same as per the working controller. As this will be applied to your clients as opposed to you browsing to the Captive Portal via the controller.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Initial role is correct on both working and not working controllers
