Highlighted
Re: Error when checking for latest firmware
6.5.4.3 is the latest that can be obtained by "Check for Firmware".  It should only upgrade you to what is here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/27582/Default.aspx
If you are on firmware later than that, it should not upgrade automatically past what is on that page.  If you have hardware that requres 8.3, please let TAC know.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
The Limited Lifetime Warranty info is here:  http://www.arubanetworks.com/assets/faq/FAQ_product_warranty.pdf
From my understanding, the "check for updates" provides you with the latest software that is shipping with the product.
 With that being said, there is probably an issue with the Check For Updates button that needs to be fixed.
Highlighted
Contributor II
I have a small cluster with a mix of 303H and 205. The 303H can take 8x code but the 205 can only go up to 6.5x
Check firmware failes with this error. My understanding is that we need to manually update each one. The GUI expects a URL but the help mentions it can be a local image.
What URLs do we use? Or does it have to be a local TFTP/HTTP server?
Highlighted
Contributor I
I have 2 -315 I bought as referb from HP for my house and they are doing the same thing. they are on the 8.x code the DRT updated but the code will not update lol
