Guest CPPM problem login
 I have defined a self-registration page for the Guest Network on IAP 103 and CPPM 6.8, but I cannot authenticate the client to the guest network.
I have a wildcard certificate set for ClearPass - https and IAP- CP.
When the client logs into the Guest Network, the registration page is displayed. When the registration page is completed, logging data is generated. I'll put the Log In button in the browser and redirected it back to the registration page. This is repeated over and over again.
Thanks for your help
Paul
Contributor I
Re: Guest CPPM problem login
With a wildcard cert on IAP you need to use captiveportal-login.DOMAIN.TLD
So in CPPM under Login your IP field should be that.
https://community.arubanetworks.com/t5/Controller-less-WLANs/Does-IAP-support-wildcard-certificate-for-captive-portal/ta-p/292431
Thank you. This solved my problem.
Paul
