Contributor I
Re: High CPU on mesh portal IAP 175
It is possible to disable DFS in instant mode?
Super Contributor I
You can change the allowed channels arm can use by do the following in the CLI:
(Instant AP)(config)# arm
(Instant AP)(ARM)# a-channels <channel-list>
(Instant AP)(ARM)# end
(Instant AP)# commit apply
http://community.arubanetworks.com/aruba/attachments/aruba/IAP/6226/1/Aruba%20Instant%206.4.0.2-4.1%20CLI%20Reference%20Guide.pdf
ACDX #419 | ACMP |
Super Contributor I
You can also do it in the GUI (had to get into my instant demo to take a look). If you go to RF -> Show Advanced Options and select Customize Valid Channels under Access Point control then you can edit the allowed channels. See attached image.
ACDX #419 | ACMP |
Contributor I
Thanks a lot! In logs there was problem with channel 100+. I changed allowed channel from 36-64. Unfortunately this is global settings (in fact I could set it only on particular AP) - I will monitor behaviour the whole WLAN from radio point and I hope it will be work.
