Re: How to allow 40MHz width in ARUBA 135
Please PM me so I can send you a link to it.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
We had pointed APs towrads down itself. The client match is disabled earlier itself. Which should I use for band steering? At present we are only having 2.4GHz clients.
 We are not getting enough speed as we are receiving only 10MBPS at server. Yesterday we had received 310 GB data at server end from 6 APs but we should receive 700 GB atleast in 10 hours.
     Please suggest
If you only have 2.4 GHz clients, the client match setting does not matter.
Did you try turning down the max power on the access points?
 Yes I had tried that also.
Please open a TAC case so they can get the full picture and help you.
 I am planning to take 5.8 GHz clients. Will IAP 135 support 5.8 GHz clients?
   Please share me the latest firmware for ARUBA 135
mail2mdileep@gmail.com wrote:
Yes.
