Highlighted
Occasional Contributor I
How to create more than vlan for management AP on Aruba 7210 Mobility Controllers ?
Dear all,
Is now, I have working in building with 3 block A, B and C. I want create 3 vlan for manager access point in 3 block.
Block A: 192.168.10.0/24
Block B: 192.168.11.0/24
Block C: 192.168.12.0/24
But when I check on Controller I see only one Vlan can be use for managerment AP
 Everybody can help me how to create more than vlan for managerment AP in building.
Thanks and regard,
Accepted Solutions
Highlighted
Frequent Contributor I
Re: How to create more than vlan for management AP on Aruba 7210 Mobility Controllers ?
You can choose 1 VLAN for the Wireless controller and you can still use all of your 3 blocks for the AP's. All you need to do is either provision the AP with the fixed IP address of the controller under AP Installation , Master Discovery, or you make sure aruba-master is well known everywhere in the network (DNS) with name pointing at the the IP Address of the Wireless Controller.
(and make sure those 3 blocks of networks are capable on seeing each other)
View solution in original post
All Replies
Highlighted
