Highlighted
Occasional Contributor I
How to determine IAP part number?
Hello. I have a number of IAP 315s. I can retrieve the model number with show version, but I'm having trouble finding the part number. I tried putting the serial number in the HPE warranty check, but it wouldn't tell me there either. Short of climbing a ladder to pull one down, how can I determine the part number of the device? For reference, you can see there are a few IAP 315 part numbers in the document I've linked below. I realize it's likely mine is either JW813A or JW813ACM since I'm US based, but is there a way to tell for sure via CLI or GUI maybe?
https://www.arubanetworks.com/assets/ds/DS_AP310Series.pdf
Highlighted
MVP
Re: How to determine IAP part number?
for US based IAP-315 here are the part numbers
JW813A             Aruba Instant IAP-315 (US)
JW814A             Aruba Instant IAP-315 (US) TAA version
If a reply adequately addresses your issue, please click on the "Accept as Solution"
