Highlighted
Re: IAP-205-RW Mesh
Hi everyone,
Just to thank you all for being so helpful. The problem solved once I upgraded the firmware to 6.4.4.8-4.2.4.4_57496
Thanks again and God bless !!!
Alfredo
View solution in original post
Highlighted
Anonymous
Not applicable
Re: IAP-205-RW Mesh
PERFECT!!!! Glad to hear your good to go.
Highlighted
Re: IAP-205-RW Mesh
Thanks a lot Jamie !!! I am getting excited with Aruba Networks and Aruba Community.
Alfredo Debasa
HPE Technical Support Specialist
Highlighted
Re: IAP-205-RW Mesh
Alfredo Debasa
Highlighted
Re: IAP-205-RW Mesh
Yes Jamie !!! The Mesh is working properly now. I just upgraded the firmware and bang, bang !! Solved.
Thank you and the others for being a great help !!
Alfredo
