Highlighted
IAP-207RW and IAP-303RW
In a company I am using 03 IAP 207 RW (firmware 8.3.0.10) managed with the virtual controller and everything works well. Can I add an IAP-303 RW to the virtual controller? I did a test but in the VC the access poit 303 is seen with the red mac address.
thanks
Cristiano
Highlighted
Re: IAP-207RW and IAP-303RW
It looks like Cluster should be upgraded. Did you check any error in the dashboard.
Dinusha Chandrasinghe
Network Engineer -Enterprise System Solution @PlexusGlobal
ACMP | ACSA | ACCA | MCSA
Highlighted
I'm doing the configuration remotely and certainly the AP-303 has a more recent firmware version of the 207 ...
I have a warning and an error of which I attach image.
Thank you
Highlighted
All APs in a cluster need to be running the same firmware version.
I could not determine the version running from the attached screenshots. What version is the existing IAP-207 cluster running, and what version is the IAP-303 trying to run?
Charlie Clemmer
Aruba Customer Engineering
Highlighted
