Re: IAP 225 Mac iOS problems
Transit power is set to Min: 9, Max: Max
That range is too large.  The range should be no more than 6 between min and max.  You should make the max 15.  Too much power or asymetrical power can cause pauses and roaming issues like you have observed.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Many thanks joseph and great response, we will follow your recomendation and try this settings!
It may not help 100% but having the AP power at maximum causes sticky clients and disconnects.
