I am trying to configure a Point to point link over Wifi wich a mesh of IAP 315 as portal devices that are wired and one IAP 315 as point device wired with an wired device.
Switch -----> IAP 315 (1) Mesh ))))) (((((( IAP 315 (2) Point ---->POE Switch (manageble but not configured) ---> Device
I configured all like described in the Forum:
- Extended SSID Disabled, all my devices are Portals included the IAP that should be moved to a different location an connect over WIFI.
- Restart all devices.
- Plug the Point IAP to his final location
- Enable Eth0- Bridging
After doing this, the device get shown in the APs list for a few seconds after it, it desapears and I have no link anymore.
Notes:
The IAP 315 (2) has an static IP, same network as IAP 315 (1) DHCP
In the Cluster, under System --> Uplink: WIFI SSID is not configured, as default.
Wired port:
VLAN is as:
Trunk
Native VLAN 1
Permited VLANs ALL
Security all deactivated
Edited:
Wired --> Edit Wired Network: Admin Status is "DOWN"
This Option enables the Ethernet Port 0 ? After setting it as Bridge?
Someone have an idea why I lost my link after enabling Eth0-Bridging?
The switch shows POE connection but no link, the IP is not pinable.
