Highlighted
IAP 325 controller base always need to reset ( AP hang )
hii.. already deploy IAP 325 controller base at small airport
33 units Ap and 1 controller
 only 4 unit at departure area always need to reset ..
the other AP no problem ..
distance betwen AP at departure area 35 meter
RF for  radio 2.4 and 5  set to default
any idea  ?
tq
Highlighted
MVP Guru
Re: IAP 325 controller base always need to reset ( AP hang )
Do you have the tech-support from the AP which are having the issue? What firmware version are you running? Has this just started happening? Has there been any changes to your environment?
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Highlighted
hii craig..FYI
- no tech support, my IT vendor disappeared
- current controller version  = 6.5.1.4
- after 3 month installation
tq
