Highlighted
Contributor I
IAP 370 - Not showing up in Airwave
We're trying to add an IAP 370/4 to our cluster but it's not appearing in Airwave - we're running Airwave 8.2.8.2, I notice the minimum software requirements for the IAP 370 mention ArubaOS & Aruba InstantOS 8.3.0.0.
Does ArubaOS/InstantOS have any relationship to our Airwave version?
Anything else I'm missing here with adding a 374? We mostly have 270/5 units currently, but have never had this sort of issue.
Accepted Solutions
Highlighted
Re: IAP 370 - Not showing up in Airwave
In an IAP swarm, all AP's should be same version for the cluster to form.
View solution in original post
All Replies
Highlighted
MVP Expert
IAP 370/374 have support in Airwave, if it still not discovering in Airwave after adding airwave ip details in IAP, need to check if any network issue or any service is down in system>status page which causing this issue.
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
Contributor I
It appears that this issue is related to firmware - we're running version 6.x on all of our other APs, this one came with v 8.3 out of the box.
I believe we'll need to update all the APs to 8.3 for the new AP to join the swarm, is that correct?
Highlighted
