MVP Expert
IAP-RAP to 7210MC - tunnel up, iAP works, client doesn't
the iAP management IP is available and I can log in to the GUI - yay!
the iAP can talk to Clearpass, so I'm getting RADIUS and MAC-auth, etc. - yay!
the iAP can talk to Airwave so I can manage it - yay!
When I attempt to connect a client, I see the dot1x request/approval with Clearpass and everything looks great except the client never gets an address assignment.
I'm using VLAN 60 for the iAP and it's IP is set from the controller anchoring the VPN.
I'm using L2,Centralized DHCP on VLAN 61 for the client (and I've tried 60 in troubleshooting)
The DHCP request makes it to the DHCP server and I have captured the response from the server on the way back to the controller - but I never seem to get the response at the client.
I'm sure I'm missing something simple, but I don't know where to look in the controller to see whether it's dropping or passing the response.
Anyone got a tip?
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
MVP Expert
Re: IAP-RAP to 7210MC - tunnel up, iAP works, client doesn't
Solved!! -- Shot myself in the foot.
We have two DHCP servers, one in the same datacenter as my controller, one remote. DHCP answers from local were working, remote were getting misrouted.
Fixed my routing typo: all better now.
--Matthew
