This community is currently in a read-only state due to a maintenance window. For more info click here
Highlighted
IAP Reboots due to warm-reset
ArubaOS (MODEL: 515), Version 8.6.0.4
Website: http://www.arubanetworks.com
(c) Copyright 2020 Hewlett Packard Enterprise Development LP.
Compiled on 2020-04-02 at 21:09:45 UTC (build 74969) by p4build
FIPS Mode :disabled
AP uptime is 32 minutes 56 seconds
Reboot Time and Cause: AP Reboot reason: BadAddr:3a3a3038656680 PC:wlc_mutx_bw_policy_update+0x3e8/0x2838 [wl_v6] Warm-reset
Accepted Solutions
Highlighted
MVP Guru
Re: IAP Reboots due to warm-reset
Can you try to upgrade to 8.7.0.0? For the 505/515 there is a chance that it will fix the issue. If you can't or don't want to blindly try upgrading, please reach out to Aruba TAC to let them investigate the logs and find the exact reboot reason.
View solution in original post
All Replies
Highlighted
MVP Guru
Highlighted
Thank you Herman, I'll try that.
