Highlighted
Regular Contributor I
Re: IAP autojoin mode - how?
Good thread here, i thought whether this could fit here too. If having 2 locations connected with VPN to each other but different subnets, could IAP connect to each other , im not sure if the traffic is tunneled between those (i dont think) so this cant properly work if having other subnet on branch location.
if having controller_based APs then this is working fine, but i dont think this could work with IAPs .e.g. you have HQ with 3 IAPs and then one branch connected via VPN and 1 IAP outside and then having some construction of 4 IAPS ,
Not working or?
regards
Highlighted
MVP Guru Elite
You should have difference VC...
One by Subnet !
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
