I have done research on this, but am struggling to find the correct answer.
I am setting up a second separate IAP instance running 8.5 from our legacy IAP-205 6.5 instance.
I took a spare IAP-305 (JX945A) on exactly the same 6.5 version and added it to its own VLAN. I have imported the 6.5 config from the first instance and upgraded (this took many hours) to 8.5.0.10 - this seems to work fine - clients connect etc.
I am now trying to add in some new (I)AP-375-RW (JZ172A). These can run instant as if I add them into their own separate VLAN and factory reset them, they will let me login to their own instant controller. I have upgraded each of these 375 APs to 8.5.0.10.
The IAP-305 is set to be my master.
Sometimes (after many many hours) they will appear in my IAP-305 controller, but I am unable to save settings, and the radios are off (they are all sitting next to each other at the moment, so maybe the controller is doing that to stop interference)?
Are these supposed to be compatible with an instant controller? Do I need to use a 375 as the master with only 375 access points?
Thanks.
