Highlighted
Is it possible to convert AP314 JW759A to IAP mode?
I've a short question about Aruba AP314 Access Point, is it possible to convert them to an IAP with a controller or via console port?
Customer has an active IAP enviroment and would like to add four AP314 JW759A.
best regards
Accepted Solutions
Highlighted
MVP Guru
Re: Is it possible to convert AP314 JW759A to IAP mode?
You cannot convert an AP314 to an IAP314. You can however convert an IAP314 to an AP314/ The AP would need to be purchased as an IAP model. You can confirm the exact model but looking at the sticker on the back of the AP.
JW759A = Aruba AP-314
An example of an IAP is JW805A = Aruba Instant IAP-314 (RW)
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
View solution in original post
All Replies
Highlighted
MVP Guru
