So I somewhat did that.
I paperclip Reset B and C and they properly came back online and joined up with A again. This is all in, what I assume is, the "New UI".
I confirmed Extended SSID is disabled
- Configuration / System / Show Advanced / Extended SSID = OFF
- Does it matter that in the Config / Networks there is an ESSID? I assume thats different and is just the name people see when they search for WiFi.
Create the Mesh SSID:
- No idea how to create a MESH SSID.
- I have created an Employee and Guest Wireless network
- - Corp is using WPA2-Personal, WPA2-AES according to Dashboard/Networks. Simple 8 charachter passphrase for now.
- - Guest is OPEN, using WPA3_OWE according to same.
- I have verified the VC Key and VC Country are set globally (Maintenance / Config) and also SSH'd into each AP and verified the same there (show cofiguration)
- show cluster on AP "A" shows me details from A, B and C.
- - A is the current VC
- show cluster on AP "B" only shows me details from B
- show cluster on AP "C" only shows me details from C
After I changed the settings on B and C, post factory reset, mainly just giving them static IPs and changing their names, I saved and rebooted ALL 3 APs using Maintenance / Reboot / Reboot All.
I then waited till everyone came back to life and was happy.
Unplugged C from the PoE switch.
Moved it to about 15 feet away from A and maybe 20 feet from B, and plugged it into a 12V power brick.
The Green System LED blinks like its booting, but never goes solid like the others on the PoE switch do.
There is Nothing plugged into the E0/E1 ports, USB, etc, just the power brick and thats it.
After a while i see a Red LED and then it reboots shortly after and looks like its in some form of loop.
New config dump attached.
I've hidden a few fields like passwords, passphrases and company name, but otherwise this is the complete dump.
Aside from AP Name and the encrypted passphrase, A/B/C are all identical in their config.
EDIT: Poking around in the CLI I see these 3 commands:
mesh-cluster-key
mesh-cluster-name
mesh-disable
Do I need to specifically configure the Mesh Cluster and Key?
The online help didn't say I needed to do that, so thinking thats perhaps for more complex configurations than my little 3 AP environment.
