Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Point to Point deployment - find the right product
I have a client with one main building with instant ap and airwave as management tool, and we need to extend the wifi outside of the main building, there my customer has a scene/tent, (distance is only 20 meters from the main buildning).
We will install 4 iap access point inside the scene/tent,  but we need a point to point solution with aruba. I know that aruba has mesh techology and outdoors access point, and i try to find the right product for this purpose. Except the aruba 387 which is dedicate for point to point, can you recommended to me another product from aruba ?
Best regards
Alex
Highlighted
Re: Point to Point deployment - find the right product
The requirement is simple, if you are looking for another option, you can look at either 377 or 367 both are with directional antennas and can serve well in this scenario.
ACMP / ACSP / ACCP / ACEP / ACDX # 663
CCIE R/S - 37956
Highlighted
Thank you for your answer. Those models working with mesh technology ? In an Instant mesh network, the maximum hop count is two node, and we need at least 3-4 access points. So its not a right solution for our purpose.
377 or 367 working with mesh or have the same functions as 387 ??
Highlighted
What if we can design it on 3 clusters. Main building running its own cluster, Tent running its own cluster and point to point 2 x APs running their own.
Or you can have 1 cluster stretched across the bridged link (it will not be part of same cluster) by bridging both ends with same Vlan.
I havent tried it before, but i think it should work.
CCIE R/S - 37956
