Re: Problem with IAP dhcp relay
unfortunately no.
The DHCP scopes, distributed/local/centralized, are to be used with VPN server/controller.
apart from them, i dont see a way to define DHCP helper on the IAP, and one will have to do it on the gateway. IAP would just bridge the traffic on the switch.
Contributor I
Ok thanks for the answers.
we have filed internal enhancement to have this in future.
